Power doesn't put to sleep
This is a discussion on Power doesn't put to sleep within the Nexus One Development & Hacking forums, part of the Nexus One category; I am rooted and if I press power it doesn't go to sleep anymore, is this normal?...
Results 1 to 10 of 10
Thread: Power doesn't put to sleep
    Senior Member Zehlek's Avatar
    14 times
    Quote Originally Posted by Zehlek View Post
    Read this
    Nexus One never sleeping - xda-developers
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    It will go to sleep after 30 seconds, but if I press the power button, nothing happens. If Io hold power I can select Airplane, Power off, reboot, silent
    Member tlgem's Avatar
    Under settings - accessibility did you check power button ends call by any chance? If its not that you got me
    If I go to Accessability, it is darkened and I can't select it
    When unexplainable things like this happen I usually bite the bullet and reinstall the rom
    Its a pain but thats probably the best way to go
    Wipe reset to factory, cashe & dalvik and then reflash the rom
    Its happened to me a few times
    Junior Member CursedAnubis's Avatar
    Did you change the end button settings in the spare parts? I did that and I didn't realize they considered the power button the end button and spent a day reinstalling and trying to figure out why I couldn't put my N1 on standby anymore lol.
    Quote Originally Posted by CursedAnubis View Post
    Awesome thanks, End button behaviour was set to do nothing, I changed to sleep and it worked. Thank you, this way I don't have to re flash. I just can't wait for cyanogen to create a custom 2.2 Froyo
    Well I just learned something today cause I changed that setting on mine and it didnt do anything different ? maybe it only takes effect on reboot
    Anyway glad you got it straitened out Zelhek
    As for froyo you might check out the paul obrien r17, or rodriguez versions over at Nexus One Android Development - xda-developers
    I have only tried those 2 - there are more - pauls is more stock while rodriguez has added more customization
    That is unless you want to wait for cyanogen
    Junior Member andyux's Avatar
    CursedA- thank you
    I had unistalled spare parts, but i guess i did modify that before and behaviour remained. Reinstalled and set button to sleep. ahhhhh sleep....
andriod tablet doesn sleep
android doesnt sleep
android phone doesnt sleep
android tablet doesnt go to sleep
galaxy s4 power button not always puts to sleep
nexus doesn't sleep
power button doesnt sleep android
power button wont sleep s4 android
