Tried to root: no signal & "Process System Not Responding"
This is a discussion on Tried to root: no signal & "Process System Not Responding" within the Nexus One Development & Hacking forums, part of the Nexus One category; i did that same problem, is there away to relock my nexus one and remove the root?...
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Tried to root: no signal & "Process System Not Responding"
  1. #31
    Junior Member smshady's Avatar
  2. #32
    should i flash the zip-file that we name update.zip?
  3. #33
    Senior Member rioja's Avatar
    You want to flash a ROM not "re-root" the phone. There were 2 files, it's the second one. That's the one to flash.
    Just to ensure you have the right file, you ca nre-download it from here:
    Multiupload.com - upload your files to multiple file hosting sites!. Then rename it update.zip
    Quote Originally Posted by smshady View Post
  4. #34
    i can do that by going to recovery mode and goign to flash sd right?
  5. #35
    Yes, that will do it. I'm assuming you have ClockWorkMod recovery installed? I mentioned installing Rom Manager from the Market... this will give you ClockWorkMod Recovery.
    So you just boot into recovery mode & select "apply sdcard:update.zip" and let it install. Again, do a nandroid from the recovery screen first!!
  6. #36
    DUDE!!! thank you soo much your sooo awesome man thank you
  7. #37
    NP bro! Glad I could help you out
  8. #38
    Junior Member andys-nuts's Avatar
    Hi. I'm suffering from the same ailment
    Problem is, my SD card is not accesible through the USB. Thoughts? Any help will be greatly appreciated.
  9. #39
    Junior Member markezine's Avatar
    Rioja
    Man, I wasn't even a member of the forum, just registered to say this: THANKYOUSOMUCH!
    I though I was going to need to plug my phone to the computer everytime I needed to reboot it from now on, you just saved my N1 =D
    sorry for the poor english, cheers from brazil!
  10. #40
    andys-nuts,
    How did you mount phone? All the steps please?
    Do you have USB Debugging selected. Settings/Apps/Development
    [SIGPIC][/SIGPIC]
    San Francisco Giants
android process system is not responding
de97d4f6c3b724d8cde015a986f99b95
install-superboot-windows.bat nexus one frf91
nexus 10 processing system not responding
process system is not resp[onding on my phone
process system not responding
