What is the best rom for power saving
This is a discussion on What is the best rom for power saving within the Nexus One Development & Hacking forums, part of the Nexus One category; 50 messages with a few calls and some apps and I would easily get a couple days on Enomthers....sitting on standy by for 6+ hrs ...
Results 11 to 20 of 39
Thread: What is the best rom for power saving
    Junior Member Galloway's Avatar
    50 messages with a few calls and some apps and I would easily get a couple days on Enomthers....sitting on standy by for 6+ hrs and my phone only dropped by 3-4% yesterday, I did send a couple of texts and one short phone call during the 6 hrs. I haven't OC'd and am using the kernel that Enom includes, CPU settings are at default levels in spare parts. I use droid wall to block all non-essential apps on 3G, sync generally turned off while at work or away from wifi. While at home I am on wifi and all apps allowed full sync with all access allowed in droidwall. Most people who use Enomthers 2.13.2 comment about great battery life. I have had no FC's and no real issues with the ROM at all....it just works and works great!
    Junior Member TheMainMan's Avatar
    I have enomther and with only sync on and underclocked to about half, in one day I burn about 20% without any use. Do u think it is a bad battery
    Senior Member dragongunner's Avatar
    I am using MicroMods Desire SuperHybrid v2.4 (oops I just realized I have not upgraded to v2.5) and I think the battery on this rom is outstanding. After 20 hours of moderate use, wifi on the entire time, and sreen brightness at 50% the battery read 43%. Oh and this rom came with an oc'd kernel at 1113MHz.
    Rooted One Click Method 8/11/10
    Unlocked Bootloader 11/11/10
    Rom: CM7 RC1 w/ Honeybread theme
    Aut Viam Inveniam Aut Faciam
    (I'll either find a way or make one)
    DragonGunner
    14 times
    MIUI + SETCPU = Best Battery Life I've had yet.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Senior Member f0ul99's Avatar
    Enomther + Pershoot 2.6.35.7 + SetCPU
    Rodriguez Miui + Pershoot 2.6.35.7 + SetCPU
    Both are very good and stable. Batery life for normal use 20+ hours.
    I went with MIUI but I have two problems with it.
    1) it randomly restarts
    2) When I try to browse on wifi, it says the site is forbidden.
    Any Fix?
    Quote Originally Posted by TheMainMan View Post
    Any Fix?
    That's weird. I just installed 10.29 and everything is stable without any problems at all. I have read that last several pages over at XDA and I didnt see any mention of others experiencing this particular problem. Sorry I cant help more. MIght have been a bad install. You can try re-flashing again.
    DragonGunner
    can you give me the site where you downloaded it
    Ok. First click on this link:
    [ROM] MIUI 0.10.29 | Stock | Deodexed | CA/FR/EN/DE/AR | Arabic (#2) | English (#3) - xda-developers
    2. Click on I understand that I am probably on my own. Will download 10.29.
    3. Scroll down to english translation pack under 10.29 and download
    4. Download gapps here: http://goo-inside.me/google-apps/gap...025-signed.zip
    5. Follow these instructions:
    1. FULL WIPE (Wipe data / factory reset)
    2. Clear Cache x2 (to be safe)
    3. Clear Dalvik Cache x 2 (to be safe)
    4. Apply miui-n1-0.10.22-deodexed-signed.zip
    5. Reboot
    6. Power off again and enter recovery
    7. Repeat steps 2 and 3
    8. Apply miui-n1-0.10.22-english-signed.zip
    9. Reboot
    10. ENJOY!
    Hope this helps you out.
    DragonGunner
    Senior Member bud760's Avatar
    Quote Originally Posted by f0ul99 View Post
    which one are you using from here? You think the new one 2.6.35.8 will be ok with Rods miui or the stock miui?
    Quote Originally Posted by Yadao View Post
    Anything with an i in the front of it from Apple is not for me.
batteey saving roms
battery saving rom
best battery efficent rom
best power saving rom
best power saving rom for android
energy efficient rom android
most power saving rom
power save rom
power save s4 rom
power saver rom
power saving android rom
power saving rom
power saving rom android
power saving rom for gt9500
saver i.t rom
