PROBLEM Rooting Nexus One
This is a discussion on PROBLEM Rooting Nexus One within the Nexus One Development & Hacking forums, part of the Nexus One category; Hello, After rooting my Nexus One (with Android 2.2), the display stopped working. It shows a black screen. The bottom control buttons are working, I ...
Thread: PROBLEM Rooting Nexus One
    Android Lurker androphonic's Avatar
    Question PROBLEM Rooting Nexus One
    Hello,
    The bottom control buttons are working, I can feel the phone vibrating when the buttons are touched and I can modify the volume too, but no image.
    I tried to reinstall the OS with no luck.
    Can anyone help me ?
    DataSmith
    P.S.
    The display is not damaged because the fastboot screen shows up when I power on the phone with the trackball.
    14 times
    How did you go about rooting? Fastboot OEM unlock?
    Did you flash a recovery?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Yes, I used Fastboot with unlock.
    I followed an online tutorial and unfortunately it did not say anything about flashing a recovery, but I tried to flash a downloaded recovery image, but that failed too (the recovery screen won't even show up).
    Senior Member f0ul99's Avatar
    Flash recovery (Amon-Ra) thru fastboot (via computer).
    [fastboot flash recovery xxxxxx.img]
    Succeed then reboot recovery. Wipe then flash Rom (CM6 etc.)
    Thank you very much.
    I got it working now.
