going to flash custom rom. need some advice.
This is a discussion on going to flash custom rom. need some advice. within the Nexus One Development & Hacking forums, part of the Nexus One category; i rooted my phone using superoneclickroot and i have the superuser app
i downloaded the titanium back up app and backed up all my system ...
Senior Member
i downloaded the titanium back up app and backed up all my system and user data..
then i downloaded rom manager(free) and before flashing the recovery i went to fix permission option and tried to fox permission but it says "an error occured while attempting to carry out the previleged commands". what does that mean?
am i rooted properly???
thanks in advance.
Android.net is the premier
Android Lurker
Try installing a root only flashlight app from the market, and see if it works. The first time you run it, SuperUser should ask if you wanna grant permission...
If it works, you have root.
Senior Member
well could u name the app please...
Senior Member
i downloaded the app move2sd that requires root and the superuser app popped up so i think i am rooted right?
Android Lurker
Good question - seems they're harder to find than they used to be...
Try a screenshot app instead - like drocap2
Android Lurker
You really need to see if the app is working, which is why I suggested something simple, like a flashlight or screen cap.
Senior Member
i even donloaded procap2 and shoot me both of them requires root and both of them are working fine on my phone...i allowed the superuser permission for both the apps...
Android Lurker
Should be good then, try flashing a custom recovery. If you have an SLCD screen, you'll need to flash a newer version than the one recommended (available at the bottom of the menu, in ROM Manager).
Senior Member
well how do i know that i have an slcd screen i bought my phone in july....
Android Lurker
Just flash a newer one anyway...
- You may not post replies
- You may not edit your posts
Forum Rules
