SD Card Problem (?)
This is a discussion on SD Card Problem (?) within the Nexus One Development & Hacking forums, part of the Nexus One category; I had major problems last night I think it's the new CWM 3.0, It messed up the EXT partition and all hell broke loose. CWM ...
Results 11 to 20 of 28
Thread: SD Card Problem (?)
    CWM will flash and backup a ROM fine but when I went to do
    a restore, that's when I ran into similar problems like you're describing.
    Finally tracked it down to DT A2sd, if it's install that's when I get all these problems, not install it's fine.
    So I partition my sd card again and after that it's working.
    I had to do a full wipe and start from scratch.
    From now on it's Amon Ra for me.:D
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    Senior Member dragongunner's Avatar
    Baseballfanz,
    I agree. I believe the problems began once I upgraded rom manager. Problems began after that. I will re-partition my sd card today.
    I have never used Amon-ra but will look into it also.
    Another question, did your recovery change its looks? Mine went from the normal green lettering to bright orange-ish.
    Rooted One Click Method 8/11/10
    Unlocked Bootloader 11/11/10
    Rom: CM7 RC1 w/ Honeybread theme
    Aut Viam Inveniam Aut Faciam
    (I'll either find a way or make one)
    DragonGunner
    Re-partitioned my sd card through rom manager. Everything is working as it should for the time being.
    DragonGunner
    Android Lurker Snickolaz's Avatar
    Missouri
    My SD card screwed up yesterday too. Not sure what happened, it could have been my own fault. But I noticed my phone rebooted and got stuck at the boot screen, so I pulled the battery and when my phone booted back up it didn't see the SD card at all. Turns out I pulled the SD card out slightly when messing with the battery. Then my phone didn't see the ext partition or something... Tried several things that didn't work, then finally I ran "a2sd reinstall" from adb shell on my computer. Phone reset and all was working again! Screwed with me for a while...
    Quote Originally Posted by dragongunner View Post
    Baseballfanz,
    Yes the 3.0.0.5 is orange not green.
    Junior Member Galloway's Avatar
    I formatted and repartitioned my SD card as well, did fresh install and all is good now as well. I also changed to RA recovery instead of CW...don't know if I will go back after this little fiasco.
    Nexus One (AT&T version)
    ROM: SuperOSR-ST@-Nexus-2.2.0-AW
    Radio: 5.12.00.08
    HBOOT: 0.35.0017
    [b]Recovery:4EXT Recovery Control
    Rooted using: Universal Androot 1.6.2 beta 5
    SD Card: 16GB Class 4 SD, 1GB Ext4
    Member temasek's Avatar
    Not too sure if its the commit in RM/CW for passion where it adds support to ext4. After this commit I am hearing problems about such issues u guys having.
    hmm maybe the commit is for some other stuffs but mentioning passion & ext4, i smell smoke...............
    you guys scared me back to CWM 2.5.1.4
    Better safe than sorry.:D
    Rightfully so! Infact I scared myself enough with it I ditched CWM and flashed AmonRA instead. So far it is working great and I don't know if I'll go back to CWM unless there is a very compelling reason. My compelling reason for going to AmonRA was the fact I hardly slept the other night while trying to recover my phone! Don't want to go through that too many times if possible...
    Best advice...make sure to periodically back up the contents of your SD card to a PC or server so you can later restore them if needed.
    Radio: 5.12.00.08
    HBOOT: 0.35.0017
cwm recovery error while restoring /sd-ext
cwm restore sd-ext
error restoring sd-ext in cwm-based recovery
error while formatting /sd-ext
error while restoring /sd-ext !
error while restoring /sd-ext android
ext4+android+sdcard 16gb
