SD Card Problem (?)
This is a discussion on SD Card Problem (?) within the Nexus One Development & Hacking forums, part of the Nexus One category; When you guys switched over to Amon_ra did you do it through rom manager where it says you can switch recoveries? Is this method a ...
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: SD Card Problem (?)
  1. #21
    Senior Member dragongunner's Avatar
    When you guys switched over to Amon_ra did you do it through rom manager where it says you can switch recoveries? Is this method a good way or should I find a zip someplace and flash it?
    *Never mind. Doing it through rom manager.
    Rooted One Click Method 8/11/10
    Unlocked Bootloader 11/11/10
    Rom: CM7 RC1 w/ Honeybread theme
    Aut Viam Inveniam Aut Faciam
    (I'll either find a way or make one)
    DragonGunner
  2. #22
    How do you delete unwanted nand backup files with Amon Ra?
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
  3. #23
    Member temasek's Avatar
    Quote Originally Posted by baseballfanz View Post
    Just delete the nandroid backup sub folder. Each backup is under sub folder named BCDEAS-yyyymmdd-time
  4. #24
    Quote Originally Posted by temasek View Post
    Thank you
  5. #25
    When I was with 3.0.0.5 I reformatted and repartitioned my sd card. I thought it corrected the problems but it did not.
    As soon as I reverted back to 2.5.1.4 and all the issues that I was having ceased completely.
    I suggest to anyone still out there running with 3.0.0.5 to do the same if experiencing problems.
    DragonGunner
  6. #26
    Quote Originally Posted by dragongunner View Post
    FYI--it doesn't come in zip, but .img
    Fastboot thru ADB or flash_img thru Terminal Emulator--I have syntax if you want to do it that way. I had to cause the latest Amon just became available on RM. Before that it was 1.7.1.1?--For a long time. Gave up on CW and RM.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
  7. #27
    Quote Originally Posted by rugmankc View Post
    Ken
    Thanks Ken but never mind. Since I rolled back to an older version of CWmod all seems to be working just fine. Guess I am still a creature of habit with some things.
    DragonGunner
  8. #28
    OK,
    I think I still have 2.5.1.4 of CW, believe that is the number.
    Worked great when I was using it.
    Ken
    [SIGPIC][/SIGPIC]
cwm recovery error while restoring /sd-ext
cwm restore sd-ext
error restoring sd-ext in cwm-based recovery
error while formatting /sd-ext
error while restoring /sd-ext !
error while restoring /sd-ext android
ext4+android+sdcard 16gb
