If I flash CM7, do I still need to do flash Fix_Recovery.zip?
This is a discussion on If I flash CM7, do I still need to do flash Fix_Recovery.zip? within the Nexus One Development & Hacking forums, part of the Nexus One category; In order to maintain the clockwork recovery?...
Thread: If I flash CM7, do I still need to do flash Fix_Recovery.zip?
    Junior Member ninsei's Avatar
    No that is only in the stock ROM because that file deletes two files that restore the stock recovery but in cyanogen and other custom ROMs those files are not there.
