CM7 battery issue
This is a discussion on CM7 battery issue within the Nexus One Development & Hacking forums, part of the Nexus One category; My nexus one is on cyanogenmod v 7.1.0 and I'm using a gingerbread launcher. I'm really happy to have it working now! However, I've noticed ...
Thread: CM7 battery issue
    Android Jr Member cmdrtomalacc's Avatar
    CM7 battery issue
    My nexus one is on cyanogenmod v 7.1.0 and I'm using a gingerbread launcher. I'm really happy to have it working now! However, I've noticed something odd. My battery life has been decreased substantially. It's not THAT bad, I just find it odd that Stock ROM has better battery life that these customized ROMS. I don't use EDGE or 3G, bluetooth, and my automatic google syncing. Is there any way I could squeeze more juice out of my batter? Thanks.
    Junior Member einc70's Avatar
    Jun 2011
    Did you try the nightly builds?... it's really good on battery life
    CyanogenMod Mirror Network - Powered by TDRevolution
