yup, i managed to get it on by plugging the usb cable to my pc.. well.. i have emailed them and waiting for a reply now..
This is a discussion on Possible BRICK issue within the Nexus One Development & Hacking forums, part of the Nexus One category; yup, i managed to get it on by plugging the usb cable to my pc.. well.. i have emailed them and waiting for a reply ...
Ah clever, well i hope they get back to you asap but they are going to some problems with stock and such, have you tried cleaning the power button with some compressed air ? that might help or your button might just be buggered![]()
NEXUS ONE
11.02.2010 - SuperBoot Rooted
NOTION INK ADAM
02.05.2011 - BEAST 2.2
hmm=/ thx.. i checked the goggle support page, seems like alot of ppl also having this problem..
Power button on my Nexus One has been difficult to function. Is this a known issue? - Android Help
ah well if enough people are having the issue then google will create a special support section for it and hopefully pull their fingers out and fix it
NEXUS ONE
NOTION INK ADAM
If you can get to above image after holding track ball and power button:
You get to 'Recovery' press power. If you get a response you should see google, straight after hold 'volume up and power' which will take you to system recovery. From here I would recommend a wipe and restore. You should still be left with 2.2 (in my experience) and any apps paid etc (you know) should be in your downloads.
If you do not already, download Astro as a file manager. Keeps things simple.
Hope to help.
I have some problem:
my phone is started in fastboot but search PASSDIAG.zip/PASSDIAG.nbh & PASSIMG.zip/PASSIMG.nbh
Where i can find this files ?
thanks in advance
