Possible BRICK issue
This is a discussion on Possible BRICK issue within the Nexus One Development & Hacking forums, part of the Nexus One category; I went through the steps to unlock the bootloader and then root the phone and when I rebooted it hangs at this screen......is there a ...
Results 1 to 10 of 18
Thread: Possible BRICK issue
    Junior Member byalansmithee's Avatar
    I went through the steps to unlock the bootloader and then root the phone and when I rebooted it hangs at this screen......is there a fix?
    Senior Member xPatriicK's Avatar
    You cant even shut it down?
    Try to soft reset it
    Hold down the Power button, Volume down and trackball at the same time.
    Let me know if it worked
    Follow me on Twitter @xPatriick
    Feel free to buy me a beer if I helped you
    This is what I use on my Nexus One (ROM, Kernel, special Apps)
    Soft reset.....no go
    Quote Originally Posted by xPatriicK View Post
    No, it sure didn't. I'm now having G1 DangerSPL flashbacks. I think this is serious, I have the same post on XDA as well just to hedge my bets and so far, nothing.
    -byalansmithee
    Is the phone still stuck at this? Have you asked over at XDA? It is very possible you did brick the device.
    Possibly the first Nexus paperweight? Thats why you have to be careful when voiding your warranty.
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    Junior Member SteveRyan's Avatar
    Pull the battery and do a hard reset?
    1. Turn the power off. If your Nexus One is frozen, pull the battery out and reinsert it
    2. Hold the Volume Down button
    3. Press and release the Power button
    4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
    5. Select Clear Storage by pressing the Volume Down button
    6. Press and release the Power button
    7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
    How to hard reset the Google Nexus One - Know Your Cell
    Exclamation Assistance Needed Nexus 1 not working after unlocking bootloader and rooting
    The image below was in result of me switching between fastboot and hboot in the bootloader. maybe its the key?
    and no the hard reset did not work.......and if I really do have the first bricked Nexus One then I want something notarized to the effect saying so.
    -byalansmithee
    Junior Member UDareUTake's Avatar
    hey sorry to dig up this post.. but i have the exact problem as byalansmithee
    but i didnt do anything.. i just realize my power button couldnt lock my phone, so i thought it hanged, and decided to take out the battery, but after tat, whenever i put the battery back it will just go into the hard-reset mode screen
    Senior Member Nobby's Avatar
    Quote Originally Posted by UDareUTake View Post
    Have you tried the old taking out the battery for 20 mins and letting it discharge then trying again ?
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
    yup, and it worked now.. but still, my power button is dead=/
    Wait so it now works but pressing the power button does nothing ? how did you power it on ? and you might be able to get it replaced if you contact google directly ?
    NEXUS ONE
    NOTION INK ADAM
google nexus one reset did not work
nexus one brick repair
