When I run SDK setup I get the error message "Failed to fetch URL https:/dl-ssl.google.com/android/repository/.xml" Reason HTTPS SSL error.
Can anyone help please?
This is a discussion on Problems Installing SDK within the Nexus One Development & Hacking forums, part of the Nexus One category; When I run SDK setup I get the error message "Failed to fetch URL https:/dl-ssl.google.com/android/repository/.xml" Reason HTTPS SSL error. Can anyone help please?...
Go to settings and check the first option.
Froyo 2.2 Stock
RA-nexus-v1.7.0
[SIGPIC][/SIGPIC]
When you clicked on SDK-setup, below Available packages on the left hand side, there is a settings section. Select settings. Under Misc. Check Force Http://.......
Nexus One - CyanogenMod-5.0.6-N1
Amon_RA Recovery v1.7.0
2.6.33.2-cyanogenmod
kmobs@ubuntu #3
BUILD: EPE54B
Baseband: 32.26.00.24U_4.04.00.03_2
Swype BETA : NexTHEME Morph
Juice Defender
Follow me on Twitter
Thanks. Downloading data from the internet now. Trust the USB drivers will be there. Will keep you posted!
i had this problem, for reference I reinstalled the java jdk, and removed all my old ones. This fixed java, and enabled https support, allowing me to download.
Make sure you install the usb drivers once you install them through SDK.
You have to plug in your Nexus to the comp. It will give you a INSTALLING DRIVERS popup, then say the correct driver could not be found.
Go into your c://android file or whatever file has all your SDK files, and select the USB driver folder.
It should install the driver, and you should successfully have the drivers installed.![]()
@NEONmonstar
Rooted NexusOne
Cyanogen CM6 RC1 FROYO
RA-nexus-v1.7.1-Cyan
Galaxy S PRO Theme
Desire Camera
