Force 3G on T-Mobile! No more Edge!
This is a discussion on Force 3G on T-Mobile! No more Edge! within the Nexus One FAQ & How-To's forums, part of the Nexus One category; "connection problem or invalid MMI code" ?...
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
Thread: Force 3G on T-Mobile! No more Edge!
  1. #21
    Junior Member ben_nexusone's Avatar
  2. #22
    mah
    mah is offline
    Senior Member mah's Avatar
    Quote Originally Posted by ben View Post
    You must have typed it in wrong.
    *#*#4636#*#*
  3. #23
    Member Dmstarr's Avatar
    What happens if...
    You want to swich back for some reason? How do you do that?
    Quote Originally Posted by Apogee View Post
    Downstairs in my house my phone likes to switch over to Edge but upstairs the 3G reception is just fine.
    You can "force" Android to only operate on 3G thusly:
    1. Go to Phone
    2. Type *#*#4636#*#* (I know, it's weird)
    3. In the Testing screen that pops up select Phone Information
    4. Scroll down an choose WCDMA only
    Your Nexus One should be happily on 3G depending on your coverage area.
  4. #24
    mah
    mah is offline
    To switch back, go through the same process and select GSM Only (which was the selection before you changed it to WCDMA only).
  5. #25
    I just did the speedtest again after trying the above settings in the same location and the numbers were much better than they were before. Numbers were worse before. Will update on how long this lasts for..
  6. #26
    mah
    mah is offline
    @americanexpat -- there's an easier way to tell which data connection you're on. The very top bar on the phone shows you if you're connected to 2G or 3G with an icon near the signal strength indicator. The icon contains an E to indicate you're connected to Edge(2G), and a "3G" for 3G.
  7. #27
    Quote Originally Posted by mah View Post
    That part I know. In Asia we have had GSM for quite some time now. So far it seems to be a bit better after this small update until now. I now have full bars of 3G reception. It still does move around a bit but definitely not like before.
  8. #28
    when i follow these steps i have a option for wcdma preferred. do you all have this option. i also don't have the bouncing problem
  9. #29
    Quote Originally Posted by johnny cizzle View Post
    Yes, just check that one. If you are in the US though that may not be the best option as reception is not as good in the US as it is in Asia on GSM network.
  10. #30
    Junior Member Ry Guy's Avatar
    Hey there,
    I'm Ry Guy, an employee from the Google Nexus One Help Forum. We just posted an update to the 3G issue and I know some of you will be interested. You can check it out here: Spotty 3G Part 2? - Android Help
    Regards,
    Ry Guy
  1. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
change edge to 3g android
edge 2 mobile network
edge 2 network
edge mobile network type
edge network type
edge to 3g android
edge2 network
how to change e to 3g on android
how to change edge to 3g on android
how to change vi data edge to 3g
mobile network type edge
mobile network type edge 2
network type edge
tmobile no 3g
whats the codes for changing from edge to 3g
