Force 3G on T-Mobile! No more Edge!
This is a discussion on Force 3G on T-Mobile! No more Edge! within the Nexus One FAQ & How-To's forums, part of the Nexus One category; Originally Posted by Dude Random21 Well not necessarily but that is what it sounds like to me so there is a way to know you ...
Page 6 of 6 FirstFirst ... 456
Results 51 to 52 of 52
Thread: Force 3G on T-Mobile! No more Edge!
  1. #51
    Member Oxente's Avatar
    Well not necessarily but that is what it sounds like to me so there is a way to know you check behind the battery on your N1 and then check there should be a model number something like PP100xxxx I can't remember exactly and don't really feel like removing the battery from myN1 right now. But check that number than Google it with at&t or t-mo version and you should find which one you have if it is true that you have the wrong version you could sell or trade it in the off topic section of this forum if you want to.
    DudeR21, You are correct - I have the T-Mo model PB99100, (3G at 1750mhz) and not the AT&T model PB99110 (3G at 1900mhz). Drat!
    Oxente [SIGPIC][/SIGPIC]
    N1 2.2.1, CyanogenMod 6.1.0-RC2-N1, Kernel 2.6.35.8
  2. #52
    Junior Member discslinger's Avatar
    thanks! this works quick and easy! I had the EXACT same problem in my office
  1. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
change edge to 3g android
edge 2 mobile network
edge 2 network
edge mobile network type
edge network type
edge to 3g android
edge2 network
how to change e to 3g on android
how to change edge to 3g on android
how to change vi data edge to 3g
mobile network type edge
mobile network type edge 2
network type edge
tmobile no 3g
whats the codes for changing from edge to 3g
