Force 3G on T-Mobile! No more Edge!
This is a discussion on Force 3G on T-Mobile! No more Edge! within the Nexus One FAQ & How-To's forums, part of the Nexus One category; Downstairs in my house my phone likes to switch over to Edge but upstairs the 3G reception is just fine. You can "force" Android to ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Force 3G on T-Mobile! No more Edge!
    Member Apogee's Avatar
    You can "force" Android to only operate on 3G thusly:
    1. Go to Phone
    2. Type *#*#4636#*#* (I know, it's weird)
    3. In the Testing screen that pops up select Phone Information
    4. Scroll down an choose WCDMA only
    Your Nexus One should be happily on 3G depending on your coverage area.
    Admin
    Guest Admin's Avatar
    Think we need to get a FAQ and How-To area and move this in there. Will work on that.
    Quote Originally Posted by Admin View Post
    FAQ and How-To area
    Sounds good although this is more of a "hack" IMO. No root required but still you are getting into the guts of the OS.
    Senior Member Fuse's Avatar
    Need hack/tip/how-to area. agreed!
    Rooted Nexus One
    Does that mean that if 3g isn't available, then you won't have any data access? Hmm, I might try this, but sometimes EDGE is better than nothing. :P
    @NEONmonstar
    Rooted NexusOne
    Cyanogen CM6 RC1 FROYO
    RA-nexus-v1.7.1-Cyan
    Galaxy S PRO Theme
    Desire Camera
    Junior Member bergman's Avatar
    quick question. i was reading today and to get 3g access for internet and things we need a data plan but do you also need something called like android internet plan or is that another name for a data plan? i am confused by this.
    jah
    jah is offline
    Senior Member jah's Avatar
    I was wondering this, too. Anyone know?
    Member jodaboda's Avatar
    You don't have to have anything more than the $10 plan, but with the $10 plan you'll have to change your access settings (the default one will tell you you need a different plan).
    I seem to get slower speeds with the $10 plan than with ATT 3G, but I'm not sure. It does say I'm on 3G, so I guess it's just not that fast (it feels pretty fast, but the test speeds are low).
    Junior Member mas90guru's Avatar
    I pay $24.95 for the BlackBerry data plan. I'd been using it with my BlackBerry 9700. When my Nexus One arrived I took the SIM out of my Blackberry and into my Nexus One without changing plans.
    So far as I'm aware you still need a data plan with T-Mobile. I'd heard previously that all Android phones required a special plan to operate -- but apparently that's not true or the T-Mobile BlackBerry plan works.
    Note that I don't use any visual voicemail or other T-Mobile features so I can vouch for how those add-ons may or may not operate under a non-Android plan.
    I'm giving this a try right now. I have crappy 3G coverage only inside my office and I frequently move back and forth from 3G to EDGE.
    The option posted allows you to change back to the original setting so nothing to lose I guess.
    I'll let you guys know as I was curious about this too.
  1. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
change edge to 3g android
edge 2 mobile network
edge 2 network
edge mobile network type
edge network type
edge to 3g android
edge2 network
how to change e to 3g on android
how to change edge to 3g on android
how to change vi data edge to 3g
mobile network type edge
mobile network type edge 2
network type edge
tmobile no 3g
whats the codes for changing from edge to 3g
