battery pulls???
This is a discussion on battery pulls??? within the Nexus One Introductions forums, part of the Nexus One category; Originally Posted by aseems Discharging your LI Battery fully (or less than 2.4 Volt per cell) is bad for the battery. Every time you do ...
Results 11 to 13 of 13
Thread: battery pulls???
    Discharging your LI Battery fully (or less than 2.4 Volt per cell) is bad for the battery. Every time you do that, it can be said that small part of your battery (some cells) dies...
    That's true for multi-celled LI batteries, but the ones in our phones are single celled.
    Senior Member f0ul99's Avatar
    This thread is usefull. Thanks.
    Banned aseems's Avatar
    Red face
    Quote Originally Posted by f0ul99 View Post
    Glad to be of Help
android battery pull
android galaxy battery pull
android how to pull baterry
are you supposed to shut down google nexus 5 android every night
battery pull for andriods
battery pull nexus 7
cm11 flightmode battery
nexus 7 batter y pull
nexus 7 battery pull
nexus 7 v2 battery pull
nexus battery pull
open droid tablet battery pull
proper battery pull android
should one shut down an android tablet nightly
