a nexus newbi with lots of problems in the UK
This is a discussion on a nexus newbi with lots of problems in the UK within the Nexus One Introductions forums, part of the Nexus One category; Hello all
I'm new to the nexus world, and to the android one as well.
currently based in the UK (Aberdeen) with a new phone ...
Junior Member
Hello all
currently based in the UK (Aberdeen) with a new phone from Hong Kong...
love the phone, problem is.. it doesn't work
I'm desperate to get it to work, but as a newbie i really don't know where to even start.
I've already posted a message regarding my issues, so i feel i should not rant about them in my intro message as well :P
i hope everyone is loving their phone, and if anyone is willing to try helping me get this show on the road i would love the help
cheers steph
Android.net is the premier
Android Lurker
First of all welcome to the forum
second of all I would love to help you (even if I`m a bit of a noob myself) but what do you mean by the phone doesn`t work do you mean it doesn`t turn on, are you refering to the phone as in you can`t make phone calls or some thing else?
Junior Member
Thanks for the welcome
I have a UK O2network 3G sim card in the phone, yet it won't connect to the network, so I'm left being stuck in 'emergency calls only' land
the phone is set to GSM only, and i can't get it out of that mode.
any and all help would be ace, i feel a bit dumb, my smart phone isn't acting smart, plus its making me feel very very dumb
Android Lurker
Are you sure it’s your phone I think it might be your sim card. Do you have another phone you can try the sim in or have you tried the phone with another sim?
Junior Member
i've tried O2 sims that work in the HTC desire phones, same 'emergency only calls' message appears.
the sim is a new one (got it on Friday), but i currently use it in my old phone, and it works fine, so i feel i have ruled out sim problems... but it was my first tough as well
Android Lurker
Under settings, wireless and network settings, mobile networks, there should be an option to enable / disable 3g. Make sure that is selected to 3g.
If that doesn't help, try going to Access Point Names, create new APN, then in name column type ' internet' (without apostrophes), in the APN column type ' internet', in the username column type ' web', in the password column type ' web'. Leave everything else blank. Press menu and save. Then make sure this apn is selected (green check against it). Try the internet and see if that helps. If not you can always select your original apn.
Android Master
Late Post Floogle covered most of it:
I am not good at this either. But you can try different settings here:
settings/wireless and networks/wifi settings/menu/advanced/regulatory domain
I know they are wifi, but will still need set for you area, not sure which channel to use.
Also, find out your APN settings for your carrier and input them:
settings/wireless and networks/mobile networks/Access Point Names
make sure the othe settings on that page are correct.
[SIGPIC][/SIGPIC]
San Francisco Giants
Android Lurker
Actually for o2 I think your apn settings for 3g might be different than what I posted...check out this thread:
O2 Forum :: View topic - No 3G support for HTC HERO??!!! ignore the fact it says for htc hero. Should work on nexus.
Just a thought, your phone isn't in airplane mode is it, With calls disabled?
Junior Member
in the mobile network settings, the data is enabled, but for some reason i can't manage to un-select the use only 2G option, i clicked on it, and it went Grey but stayed checked. when ever i come back to that screen after having tried to uncheck the only 2G networks box, its always check on again...
also tried your internet APN option too but nothing changed
Android Lurker
Originally Posted by
edwizz
Did you create a new apn? After creating it, did you press menu button and save?
Was the phone brand new? You could try a factory reset, to see if it makes a difference whether you can select 3g option.
- You may not post replies
- You may not edit your posts
Forum Rules
