Nexus One - Power button issue
This is a discussion on Nexus One - Power button issue within the Nexus One Introductions forums, part of the Nexus One category; Hi,
My Nexus One replacement (free replacement after the first one had the 'stuck forever on the X while booting' problem thankfully within warranty) had ...
Junior Member
Hi,
My Nexus One replacement (free replacement after the first one had the 'stuck forever on the X while booting' problem thankfully within warranty) had the power button issue - ie. cannot get the screen activated as the power button does not function at all. Thanks to Destil and the "Fix Broken Power Button" app I am able to use the phone. However, one in about 15 incoming calls hangs after I have installed this app. I cannot do anything while such a call is ringing and eventually the Phone app shows the 'Force Close' dialog. Any ideas on how I can get around this issue.
I used to work on some mobile software projects for Symbian and I remember one of the non-negotiables being that the application software should *never* disrupt the usage of the phone as a regular phone. This fundamental, cardinal rule is violated time and again by Nexus One.
All in all, the phone isn't as robust as it should be is my conclusion. I hope Google is listening.
regards,
- gk
Android.net is the premier
- You may not post replies
- You may not edit your posts
Forum Rules
cannot power on nexus 7
how to fix google nexus one power button
how to nexus one power button diagram
nexus 7 cannot power on
nexus cannot power on
nexus one cannot on
nexus one power button problem
power button diagram for nexus one
