Need help with my Nexus one bluetooth
This is a discussion on Need help with my Nexus one bluetooth within the Nexus One Introductions forums, part of the Nexus One category; Hi
I got a Nexus one (google phone) for two month now and just joint as a new member.
I bought a Mini Bluetooth 2.0 ...
Junior Member
Hi
I bought a Mini Bluetooth 2.0 Keyboard - The description claims it works With iPad/iPhone 4.0 OS / Android 2.3 / PS3 / Smart Phone / PC & Mac
But I cannot get it to connect to my phone! It works with IPhones (tried with a friend) so it is working.
Does anybody have some idea what I can do to get it to work?
My phone is on Android version 2.3.4
Cheers.....Markus
Android.net is the premier
Android Lurker
Hi Markus, and welcome!
What have you tried, and what errors are you seeing?
Have you been able to connect other Bluetooth devices to your phone?
Junior Member
mini keyboard connection problems
my phone can see the keyboard but pairing already is a problem. It asks me to put in a code - without that I can't go to the next step. So I tried it with "0000" and "1234" but nothing worked.
When a friend tried it on his IPhone, it showed him to input something like "1260" which I used for my phone.
That was accepted! and it showed me as "paired but not connected".
Well, that is as far as it goes. It just never seems to connect. No error really. Just nothing happening (like a timeout).
It connects fine to the IPhone and works as expected so I don't think it is the keyboard that is the problem.
Any ideas?
Help is very much appreciated!
Markus
- You may not post replies
- You may not edit your posts
Forum Rules
bluetooth nexus one error
mini bluetooth nexus 1
