Upgrade from 4GB to 8GB MicroSD. Help.
This is a discussion on Upgrade from 4GB to 8GB MicroSD. Help. within the Nexus One Introductions forums, part of the Nexus One category; Greetings, what's the best way to upgrade from a 4GB MicroSD to an 8GB one? I'd like to preserve everything already stored in the SD. ...
Thread: Upgrade from 4GB to 8GB MicroSD. Help.
    Junior Member simone.brunozzi's Avatar
    Greetings,
    what's the best way to upgrade from a 4GB MicroSD to an 8GB one? I'd like to preserve everything already stored in the SD. However, form my Mac it's not possible to browse the nexus one via bluetooth.
    Suggestions?
    If I'm able to browse it, should I just copy the old files to the new 8GB card?
    Member tribz's Avatar
    Check out this thread ...
    http://www.nexusoneforum.net/forum/n...procedure.html
    And search feature works great ;-)
how to expand 4gb micro sd to 8gb
how+to+expand+4gb+micro+sd+to 8gb
upgrade 4gb to 8gb micro sd
