wi-fi connection problem
This is a discussion on wi-fi connection problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; hi guys, I would like to use my n1 to connect to the internet via wi-fi in my uni. However, my uni require me to ...
Thread: wi-fi connection problem
    Junior Member joel_nexusone's Avatar
    hi guys, I would like to use my n1 to connect to the internet via wi-fi in my uni. However, my uni require me to install a file to access the wi-fi. I had tried to d/l the file and try to unzip and install it. I just wondering, where i should store the file in n1? Do i have to create new folder in my memory card just like storing songs? Or what else i could do with it?
    UK
    8 times
    Nd1razor
    You could try my tutorial, N1 doesent work well with proxys, iv tried.
    And there area any good proxy server apps out there
    http://www.nexusoneforum.net/forum/s...our-phone.html
    Quote Originally Posted by Fury View Post
    the file that i had upload is download from my uni webpage which is what they want me to setup in my phone
    but it just said unzip fail
    Attached Files Attached Files
    first, that zip file is corrupt and can't be extracted. you could redownload it, but i don't think it will do you any good...looks like it's meant for windows mobile ppc's (pocket pc). you may need to contact the it dept at your university to sort this out...
