CRAZY 16bit color issue! Test yours!
This is a discussion on CRAZY 16bit color issue! Test yours! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; you'll also notice that when you move around the image it will clear up...
Results 11 to 12 of 12
Thread: CRAZY 16bit color issue! Test yours!
    The Nexus One's Dirty Display Secret (Updated) - Nexus one screen - Gizmodo
    http://www.nexusoneforum.net/forum/n...ink-ahead.html
    "UPDATE II: Multiple reports from users are claiming that some third party apps—galleries and browsers—eliminate the image banding seen above. This points to a software issue rather than a hardware issue, which means that Google could conceivably fix some aspects of this display strangeness with a software update."
android 16bit color
