Battery Issue
This is a discussion on Battery Issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; so Quick update, just got a replacement, battery and back cover and that seem to have solved the problem, no more clicking noise! I would ...
Results 11 to 13 of 13
Thread: Battery Issue
    Junior Member Harry454's Avatar
    so Quick update, just got a replacement, battery and back cover and that seem to have solved the problem, no more clicking noise! I would like to thank Tangie at HTC for the help she provided as well, if you get a hold of her when you have problems you are in good hands!
    Quote Originally Posted by Harry454 View Post
    Thanks for the update...
    Glad to hear it's all sorted.
    As long as you don't hear a "ticking" noise, I think you're safe
android one battery issue
