Reset to factory settings after rooting my N1
This is a discussion on Reset to factory settings after rooting my N1 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Is there a way to flash back the original ROM ? I'm planing to return my phone, and I don't want any problem with HTC. ...
Thread: Reset to factory settings after rooting my N1
    Junior Member tunisiano32's Avatar
    Any idea or link that can help me ?
    Thanks
    You can only go back to the original ROM if you have a saved back up. You can just flash it back from the back up, and everything should be good.
    Junior Member ajohnson253's Avatar
    Red face
    I know I really sour stupid, but I'm brand new to the N1, how do I back up so I can restore just in case I root and would like to go back. I'm in front of beginner its that bad
    Junior Member mdoades's Avatar
    My understanding is that if you unlock the bootloader and root the N1, you can go back to the stock rom, but your bootloader will remain unlocked and your warranty will still be void. Was this your question, or did I take it way off topic?
asus padfone restore factory setting after root
can you factory reset your nexus phone after rooting
factory reset zto n1 tablet
galaxy nexus back to factory after root
how do i set the zto n1 tablet back to factory
how to restore factory n1
how to return galaxy tab to factory settings for rooted device
how to set nexus 7 back to factory settings after unrooting
padfone root factory settings
reset back to factory settings samsung nexus
reset nexus one to factory settings
restore nexus one to factory settings after root
return 6to factory presets-korg n1
wipe galaxy nexus after rooting
