Nexus One 3 UK internet setting problems
This is a discussion on Nexus One 3 UK internet setting problems within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I've spoke to three & got another bunch of settings.. He said there internet doesn't work in areas covered by orange. . Which is a ...
Results 11 to 20 of 20
Thread: Nexus One 3 UK internet setting problems
    Junior Member AHutchinson's Avatar
    He said there internet doesn't work in areas covered by orange. . Which is a lie.
    I think im just gonna go with o2.
    Ill try emailing HTC first though.. have you got their address?
    Quote Originally Posted by AHutchinson View Post
    HTC - About HTC - Contact Us by Phone
    click the link and use the email on the left side of page
    Brilliant! Thank you
    Junior Member alpen's Avatar
    Can you post their response here pls? I don't want to send a duplicate email..
    Got a reply, they gave me the exact same details that 3 did this morning..
    So no idea what's going on. It must just be weird coverage in my area. I'm going to drive to an area where i know there is 3G signal & see what happens.. Maybe i'll retrieve an EDGE signal after that.
    Anyway here was the email i sent to HTC;
    "I am having difficulty setting my nexus one up for internet on the 3uk network. I've been told that HTC have been very helpful with other people who are experiencing similar issues on the same/other networks. I am able to send & recieve texts and calls but internet won't work at all. I live outside a 3g area but never had issues on my old phone in Edge or 3g areas. Any help would be greatly appreciated. Aaron"
    And their response;
    "Hi Aaron,
    Thank you for your email.
    Setting up the Device
    1. On the device, tap the Menu icon.
    2. Select Settings > Wireless & networks > Mobile networks > Access Point Names.
    3. Press the Menu key and select New APN.
    4. Select Name, enter 3 Services and tap OK.
    5. Select APN, enter three.co.uk and tap OK.
    6. Enter the user name and password listed below. If no value is listed, leave the field blank.
    * Username:
    * Password:
    7. Select APN type, enter default and tap OK.
    8. Press the Menu key and select Save.
    9. Press the radio button next to 3 Services to set the profile as default.
    10. Press the Home key.
    11. Tap the Menu icon.
    12. Tap Browser.
    13. Press the Menu key and select More > Settings > Set home page.
    14. Enter Mobile phones, Mobile Broadband & SIMs from 3 and tap OK.
    The settings are saved and the service is ready for use.
    Setup other services for your phone
    Please restart the device to try again.
    Best regards,
    Jozefine M
    HTC"
    HERE ARE SETTINGS FOR ORANGE.CO.UK TO SAVE SOMEONE TIME
    1. On the device, press the Menu key.
    2. Select Settings > Wireless controls > Mobile network settings > Access Point Names.
    4. Select Name, enter Orange WEB and press OK.
    5. Select APN, enter orangeinternet and press OK.
    o User name:
    o Password:
    7. Select APN type, select default and press OK.
    9. Press the radio button next to Orange WEB to set the profile as default.
    11. Press the Menu key and select Browser.
    12. Press the Menu key and select More > Settings > Set home page.
    13. Enter http://wap.orange.co.uk and press OK.
    Junior Member maokun's Avatar
    so what happened in the end.
    Have you guys successfully connected 3 uk internet?
    I'm having the same problem at the mo.
    It shows R sign next to the bar which I assume I'm using orange network as someone mentioned previously. (no G,3G,H sign at all)
    If I enable Data roaming option, then I can connect otherwise no internet at all.
    I have unlimited data add-on with 3uk, so I'm just wondering if they charge me for using this way (data roaming)
    Thank you in advance.
    Quote Originally Posted by maokun View Post
    If I have an R sign (ie connected through Orange) then I find internet connectivity is really bad (non-existent or very slow). I think this is a problem with the N1 on 3 as my previous Nokia did have internet connectivity when I was in the same physical location.
    If I have 3G then internet connectivity is good.
    I dont think 3 charge you if you use data roaming (ie Orange) in the UK when there is no 3 signal.
    I have since moved to o2. The fact that I was unable to use mobile internet was a massive deal breaker for me.
    On o2 I have perfect data connectivity.
    Can I just ask, though for possible future reference- are you on contract or PAYG? Because I couldn't get any connectivity even while data roaming was turned on.
    I'm PAYG. When the R is showing I'm having the same connectivity problems that you had. I think we can conclude there's a data connectivity problem if you have a 3 PAYG sim & roaming on Orange.
apn 3 uk setting
nexus uk net
uk
wap settings google nexus one 3
