Screen Won't Wake Up
This is a discussion on Screen Won't Wake Up within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; The same problem is being discussed at Bug: Nexus S with 2.3.4 OTA Black Screen during and after a call - Google Mobile Help...
Results 31 to 38 of 38
Thread: Screen Won't Wake Up
  1. #31
    Junior Member aakaankshaa's Avatar
    Oct 2011
    Junior Member 87NexOne's Avatar
    Oct 2011
    i thought i was the only one with this small issue! a simple reboot gets it going for me
  3. #33
    Junior Member ToniA's Avatar
    Feb 2012
    Its been months since nobody posted, anybody came up with an explanation/solution?
    This Issue just appeared in my phone after two years of use.
    -When the screen goes to sleep it won't be possible to switch it on again. Either via the power button, time up or proximity sensor.
    -The phone and the touchscreen work as always, haptic feedback reveals my unlock slider is still active and the phone can recieve calls and notifications.
    -Plugging in the phone or using another button won't revive the screen either.
    -The backlight of the screen turns on, but the screen remains black.
    -Only removing the battery and waiting at least 10 seconds before putting it in again will let the screen to come back.
    -Shouldn't be a software problem as i have wiped several times everything that could be wiped and instaled diffrent Roms, even tested ICS.
    -In my case, removing the microSD doesn't change anything.
    -Swapping batteries also doesn't help.
    Anybody out there with the same problem?
    Programmed obsolescense on HTC?
  4. #34
    Member ra990's Avatar
    Same problem. Once screen turns off, I can't get it to turn back on. This happens with or without an SD card. I am also unrooted. I have already performed a factory reset.
    Any ideas on how to fix this?
  5. #35
    Junior Member kang's Avatar
    Apr 2012
    black screen
    I have same problem. screen goes black and four buttons light up, sent for repair , same issue again. only solution is to remove battery and insert it back. please help.
  6. #36
    Member n1newbie's Avatar
    Oct 2011
    fornat ur sd card with sdformatter. see if that helps
  7. #37
    Junior Member bugmenever's Avatar
    Hardware Solution
    Hey everyone, I found a solution for my Nexus S. I dropped my phone from a low height, and I had similar symptoms to what others are describing. My phone will boot, but after the screen turns off, I can't get it to turn on again. Pressing the power button will light up the four bottom menu icons, but the display remains dark. Only way to get it back on again is to yank the battery and then power on, and the screen would activate for startup.
    So, solution! I disassembled the phone, and unplugged the main display connector and reconnected it. Take off the back of the case, take out the screws, remove the inner tray. Unseat/reseat the connector and put 'er all back together. Works just fine now. I used this video to help me with the process:
    [ame=http://www.youtube.com/watch?v=dYB5wiFFIno]Samsung Nexus S GT- i9020 Disassembly & Assembly - Screen & Case Replacement - YouTube[/ame]
    (He points out the main screen plug at 3:38)
    Hope that helps!
  8. #38
    Android Lurker rcunningham's Avatar
    Jan 2015
    I have this same issue with the software of the phone. It's ported to that's why. Can anybody find a software fix? LG Ally running a version of Gingerbread.
  1. Need App to 'Wake Up Screen with Buttons'
    By sierra in forum Motorola Droid 2 Global
    Last Post: 04-26-2012, 03:13 PM
  2. any option to having to push button to wake screen?
    By kankan in forum Motorola Backflip
    Last Post: 10-01-2010, 02:49 PM
  3. Random wake-ups with lock screen apps
    By ACCUSED in forum Motorola Backflip Tech Issues / Bug Reports
    Last Post: 08-13-2010, 11:02 PM
android phone won't wake up
android screen wont wake up
android tablet won't wake up
android won't wake up from sleep
galaxy 4 screen won't wake up after charging
galaxy s4 won't wake up
my galaxy 5 screen wont wake up
my nexus 5 display won't light up
nexus 4 screen goes black
nexus 5 screen won't wake up
nexus5 screen black won't light up
samsung s4 mini goes to sleep and wont wake up
samsung s6 active screen wont light up
the screen on my galaxy s4 active will not wake up and the charging light wont come on when i plug it in
why will my screen on lgg4 not wake up when i touch it
