MMS Not working on O2 in uk
This is a discussion on MMS Not working on O2 in uk within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi I've tried every permutation of APN config settings listed on just about every forum on the web, but MMS will still not work for ...
Results 1 to 10 of 19
Thread: MMS Not working on O2 in uk
    Junior Member stamina_josh's Avatar
    Hi
    I've tried every permutation of APN config settings listed on just about every forum on the web, but MMS will still not work for me on the nexus for my pay monthly O2 SIM. Has anyone got a fix or also had this issue? I've tried O2 support but to no avail (several times).
    cheers
    well, since you've tried every permutation of APN config, this may be of no help and perhaps you've already read this:
    Google Nexus One - o2 Settings for 3G network access and MMS | The world according to pglewis
    Apparently, there are different APN and username settings for contract and pay-as-you-go customers...
    http://www.google.co.uk/support/foru...5fd32318&hl=en
    I've really got no idea where to begin with this otherwise...are you rooted? if so, you could change your "Custom User-Agent" settings to spoof your phone as an iPhone on the O2 network...
    Hi, thanks for the link, that one is the best written one on the web but unfortunately i've tried it to no avail, along with a few others. My phone is not rooted. If the staff at O2 had a bit more skill then i'm sure it could be sorted fairly easily but they don't have any settings whatsoever for this phone.
    Quote Originally Posted by stamina_josh View Post
    click the link and scrool down you can call or email thats what i used for orange uk
    HTC - About HTC - Contact Us by Phone
    Thanks I will give it a go
    I emailed HTC and they never got back - what poor service eh !
    Do your web APN settings work ok (can you browse the inet with wireless off)?
    Hi, yes the internet works and normal SMS messages work also, but not picture text messaging. It's really strange. ONLY picture messaging doesn't work, neither sending or receiving, it's really annoying I've tried virtually everything.
    I'm sure you've already been down this path, but I'd thought Id throw it out there in case you hadn't:
    O2 Mobile Phone Settings
    Also, have you tried using the Milestone/Hero settings? Read here:
    Android Forums - View Single Post - 02 MMS/WAP settings for Hero
    In that post he mentions a modified apk for the N1...It's here:
    Android Forums
    Finally, every time you edit, remove, or reset you APN settings you've rebooted the phone, right? If not, I would strongly encourage you to do so. In fact, instead of editing them, I'd completely remove it/them, reboot, then replace with a new APN(s) entry.
    Try this on for size...first delete your current mms APN entry and reboot the phone. Then try these settings:
    Name= "o2 UK MMS PAYG" (or whatever you want...)
    APN= "payandgo.o2.co.uk"
    Proxy= <Not set> or **leave blank**
    Port= <Not set> or **leave blank**
    Username= "vertigo"
    Password="password"
    Server= <Not set> or **leave blank**
    MMSC= "http://mmsc.mms.o2.co.uk"
    MMS proxy= "193.113.200.195"
    MMS port= "8080"
    MCC= "234"
    MNC= "10"
    Authentication type= <Not set> or **leave blank**
    APN type= <Not set> or **leave blank**
    Hi, thanks for taking the time to provide the detail and try to help. Unfortunately the settings didn't work. Yes I am rebooting each time, HTC cust service have not been able to resolve this either. Although O2 customer service are friendly and helpful you get the whole Manucunian thing going on, needless to say, problem not resolved. It's really weird as I get a good 3G and web connection but just can't send MMS.
  1. When will the Behold get Android 2.2?
google nexus 1 settings o2
o2 wap and mms not working
