Wifi Disconnects When Phone Sleeps
This is a discussion on Wifi Disconnects When Phone Sleeps within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Yeah, I have the same issue. Should I go for a replacement?...
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: Wifi Disconnects When Phone Sleeps
    Junior Member resplendent2209's Avatar
    Junior Member GuardianFlash's Avatar
    I don't think switching router would fix it for me. I switched from HTC Hero to the N1. Wifi would not disconnect after the screen turns off on the Hero.
    Have you tried contacting the google tech support?
    Have you????
    Yes, they said that it looks like a hardware issue and I should send the device for repair. There was also an option of having a replacement device sent but that would have put hold for 529USD which I didnt had so I will be sending for repair on Monday.
    Quote Originally Posted by resplendent2209 View Post
    please let me know if after the repair it'll be fixed. Would I still be able to send it in for repair? I bought mine in Feb.
    Yes as far as I know you have a one year warranty. Please give a call to google tech support first and they will tell you what needs to be done next.
    I'll just wait till you get yours back and see if it solved the problem. I don't have another unlocked phone. Sold my unlocked Hero and the phone before the Hero is locked to my old provider.
    Atleast try contacting the google tech support.
    I forgot I rooted mine. My warranty is no more. I thought installing custom rom like Cyanogen would fix it, but no. So then I thought the new froyo 2.2 would fix it, but still no. Well, still let me know if google fixes yours.
android wifi dies when locked
android wifi disconnects on sleep
droid dna wifi sleep streaming problems
htc one wifi disconnects sleep
htc one wifi stay on when phone sleep
nexus 7 4.4 wifi disconnect sleep
samsung s3 android wifi disconnects with sleep
solution lock wi-fi nexsus 7
talkatone disconnects when idle
talkatone disconnects why
the wifi on my htc disconnects by itself
wifi disconnects on sleep android
wifi disconnects when phone is idle cyanogen mod 7
wifi still sleeps
wireless internet disconnects when smart phone sleeps
