Issue with edge and 3G
This is a discussion on Issue with edge and 3G within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi All, i just bought my new nexus one, i really enjoy its entire features its a great phone and really worths every penny i ...
Thread: Issue with edge and 3G
    Junior Member spearofdeath's Avatar
    Unhappy Issue with edge and 3G
    Hi All,
    i just bought my new nexus one, i really enjoy its entire features its a great phone and really worths every penny i paid for. But i am facing i problem that i cant overcome. i live in colombia and i wanna use the internet on the nexus one but the problem is that the neither the 3G or EDGE internet work i can only connect to internet through wifi. Please help me i feel so sad i wana stay connected always to internet what can i do to make 3G or EDGE internet work.
    Re: Issue with edge and 3G
    You probably need to find the 3G APN settings for your wireless provider and set it up on your Nexus One to get it working. What's your wireless carrier name?
    Movistar
    hi my network operator in colombia is movistar
    Junior Member rsteph's Avatar
    Feb 2012
    Did you find a solution?
    Hi, I have the same problem. Did you find a solution?
    movistar says that Samsung personnel must fix it.
    I use my Nexus with many other operators in other countries, without having this issue. Only movistar in Colombia.
