Headphones access problems
This is a discussion on Headphones access problems within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My headphones are working fine as for as hearing songs or calls. But the controls are not working. I am not able to cut the ...
Thread: Headphones access problems
    Junior Member nagag's Avatar
    Exclamation Headphones access problems
    My headphones are working fine as for as hearing songs or calls. But the controls are not working. I am not able to cut the call or stop the music player. I did try my headphones in a different nexus one and i was able to control music using the same headphones.
    I feel some setting is preventing this. Can you any one help me?
    Hey i had this problem. I had a application called MixZing as soon as i uninstall that application my headphone controls started working fine.
    Senior Member Zindol's Avatar
    Im having the same problem. Very frustrating. I can't figure out what app i have making it do that.
    Senior Member rioja's Avatar
    Hmmm, same here using Cyanogen mod. Interestingly, a set of 3rd party headphones with controls that I use daily work fine. I just assumed it was Cyanogen causing the N1 headphones to malfunction. But maybe not....
android phone headphone control stopped working
