Help with WiFi
This is a discussion on Help with WiFi within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi! I just got a nexus one and im very pleaced with it but i got a problem My Wi-Fi dosenīt work and i dont ...
Thread: Help with WiFi
    Junior Member Ntrix's Avatar
    Help with WiFi
    My Wi-Fi dosenīt work and i dont know why. It worked just fine the first two days and now i cant connect to any wireless networks. And when im trying to turn the WI-Fi on all it sayīs unnable to start WI-Fi and i really need some help because it is driving me crazy here at home :/ So please help me
    Senior Member astros148's Avatar
    you should try a wifi app in the market
    So what does this app do?
    Quote Originally Posted by Ntrix View Post
    Before you look for a wifi app; and it's a minor software glitch...
    Remove the battery for 3mins. > reinstall and power up.
    Or if it's a major software glitch....
    Factory reset will fix it.
