headphone control is horrible
This is a discussion on headphone control is horrible within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I can't cut calls... n only dat wen d extra button is pressed.in a call music starts. it is so annoying someone plz make an ...
Results 1 to 10 of 13
Thread: headphone control is horrible
    Junior Member avaneesh's Avatar
    Exclamation headphone control is horrible
    it is so annoying
    someone plz make an app to fix this
    someone plz respond
    I donno wad to do
    Member Deekayx05's Avatar
    Oh my GG and you not use slang or abbreviated words? Headphone control is terrible? But you're saying when you press a button during a call your music starts? What's that extra button besides the track ball?
    UK
    8 times
    Nd1razor
    Deekayx05, you dont have to be so harsh, read what he's saying.
    He wats to use the headphones to make calls, but the headphones have no pickup, and disconnect buttons, only play, rewind and forward.
    Im not sure of the solution to this, sorry :\
    an app may be the answer, or a new headset with physical buttons should work fine.
    Quote Originally Posted by avaneesh View Post
    it is so annoying
    Use English and maybe people can understand you...
    Junior Member Ryands991's Avatar
    Quote Originally Posted by jonno2k View Post
    I can't end my calls with my headset. If I press the play/pause/Answer call button while in the middle of a call (Expecting the call to end), music will start playing. This is very aggravating.
    Can someone please look into making an app to help this? (Ending a call by pressing the center button on the provided headset)
    If you try, (you shouldn't have to try very hard) you can still understand his point. I retyped his post for you.
    Junior Member nagag's Avatar
    Hey i had this problem. I had a application called MixZing as soon as i uninstall that application my headphone controls started working fine. Hope this may be helpful.
    thanks a lot you guys
    sorry that was my mistake
    the headphones have 3 buttons
    play . next song. previous song
    when I am on a call and I want to disconnect the main button mutes the phone instead of hanging up
    as a bike rider it is extremely annoying
    if in the call I press next song or previous song button which happens by mistake
    during the call music starts playing!!!!!!!!!!!!!!!
    while I am on call
    and android has serious software bugs n glitches
    nagag-
    brother I don't have any such application on my phone.
    thanks though
    Junior Member ganeagla's Avatar
    hey avaneesh -
    had same problem but if you look at the nexus one official handbook, it says that pressing the "play" (or center button) will just mute the call.
    But pressing and Holding it will end the call.
    I agree this is a little counterintuitive, as I don't often need to mute calls, but there you go.
    hope that helps.
android 2.3.1 headphone control problems
