Import Contacts from SD card - help please
This is a discussion on Import Contacts from SD card - help please within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I rooted my phone yesterday. I did "export contacts to SD Card first of all". I flashed the new ROM etc...now I'm going to contacts. ...
Thread: Import Contacts from SD card - help please
    Member firemax7's Avatar
    I flashed the new ROM etc...now I'm going to contacts. I go to Import contacts from SD card..it looks like everything goes fine (reading contacts from sd card etc..) but when it's done the contact list is still empty :/
    I have to restore my contacts!
    any ideas?
    Problem Solved *
    It was my mistake, you can delete this thread. sorry :/
    For members with similar problem...
    How did you fix your issue?
    I went at Contacts -> accounts -> i selected my gmail account and in there i pressed "sync contacts" and they appeared :P
    Thks!!
    you welcome
