Video becomes laggy, audio seems to be fine
This is a discussion on Video becomes laggy, audio seems to be fine within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, i just recently got my new nexus, and i have this problem when i try to play any video, after conversion and whatnot, the ...
Thread: Video becomes laggy, audio seems to be fine
    Junior Member SilentArchangel's Avatar
    when i try to play any video, after conversion and whatnot, the audio is PERFECTLY fine, but the video is off and slow by a whole lot...
    I HAVE converted the videos to nexus standards, using expensive software, and even youtube is like that...
    Can anyone help?!
    Quote Originally Posted by SilentArchangel View Post
    Can anyone help?!
    Describe what you mean by slow. Is it "laggy" or is the sound and video off track?
    *EDIT* Heres a way to test the file to see if its the phone or the video converter. Play the file on your computer to see if you experience the same problem. If it does that means the video converter isn't doing a good job and if it doesn't that means its the Nexus One.
    Froyo 2.2 Stock
    RA-nexus-v1.7.0
    [SIGPIC][/SIGPIC]
    actually nevermind thanks, it WAS laggy and worked fine on comp...
    but then i restarted the nexus and its fine now thanks
youtube videos seem laggy
