All incoming calls through Google Voice showing as UNKNOWN
This is a discussion on All incoming calls through Google Voice showing as UNKNOWN within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I just noticed that it's been a few days since my nexus one phone when callers dial my google voice number, the number doesn't show ...
Thread: All incoming calls through Google Voice showing as UNKNOWN
    Junior Member Laura Han's Avatar
    Angry All incoming calls through Google Voice showing as UNKNOWN
    I just noticed that it's been a few days since my nexus one phone when callers dial my google voice number, the number doesn't show up and even contacts saved, all show up as UNKNOWN. Dialing out using Google Voice also shows up on other phones as UNKNOWN/BLOCKED. I've tried to factory reset. Checked to make sure that my google voice settings were all correct and still no luck. Can someone please help me figure this out???
    Android Lurker lunchbox's Avatar
    I noticed the same .. recently all the incoming calls are showing Unknown.
    Google Voice Numbers "UNKNOWN" Issue
    After trying many ways to figure this out, I noticed that my regular T Mobile number works fine to display callers (numbers/contacts) so I've determined that it's a Google Voice problem only.
    I've sent in a Report Issue through Google Voice to see if they can fix the issues many of us are having.
    Please help voice our problem by report to Google Voice! Thank you!!!
android all calls display unknown
android display hidden incoming caller number after call
android phone all incoming calls unknown
call to my google incoming calls unknown
contact numbers not showing up on incoming calls on nexus 4
droid razr incoming call numbers not showing up
google voice shows up as an unknown number
google voice unknown number
how to get unknown numbers on google voice
tracing unknown caller calls on google voice
why are my incoming calls showing unknown on my nexus 4
