nexus one problem with top button
This is a discussion on nexus one problem with top button within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; im having a problem with my top button, for some reason it takes forever for me to activate my screen. Even after i push it ...
Thread: nexus one problem with top button
    Junior Member flobot's Avatar
    im having a problem with my top button, for some reason it takes forever for me to activate my screen. Even after i push it multile times. any one else having a problem with this as well??
    Junior Member wraithevolution's Avatar
    Don't know if you're having problems with your button or not, I have heard this can be a problem. There is a program called "nolock" on the market for free. It bypasses your unlock screen but can be toggled on or off. But it allows you to wake your screen with either the volume buttons or the trackball, no root required. I use it and love it.
    Senior Member Fuse's Avatar
    My wife had weird issues with hers. We sent it back to HTC for a new one. Give them a call.
    Rooted Nexus One
    62 times
    There is definitely a delay of several (8-10) seconds...just push it once, and be patient...it should boot just fine.
