Stopping Data Problem
This is a discussion on Stopping Data Problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi there, I have just purchased my Nexus One and I am really enjoying it. I am currently running it on the Vodafone New Zealand ...
Thread: Stopping Data Problem
    Junior Member NITC's Avatar
    Hi there,
    I am currently running it on the Vodafone New Zealand network and so far things have been great.
    My only issue is that it seems to be using a lot of data. I did a bit of research and tried the Quick Settings and APNDroid apps, but to no avail they don't seem to be working for me!
    It is quite strange - when I switch data off using Quick Settings I can still connect to websites, and when I switch on APNDroid I can still connect! I have even tried removing the APN settings (changing them to blank) but still, I can visit websites.
    Does anyone know how I can get around this and why these apps aren't working for me? Could there be a problem with my phone?
    Thanks,
    NITC
    62 times
    When you say quick settings, what are you actually turning off? You obviously haven't killed all data, as 3G/EDGE/G would still be running unless you chose airplane mode. Need more detail.
    I turn off the mobile data option in the application Quick Settings, which is supposed to stop all data but I can still connect to the net, open web pages etc
    Junior Member blaz's Avatar
    Quote Originally Posted by NITC View Post
    I believe Vodafone New Zealand allows you to connect with any APN settings. The tools you use to disable data just specify "bogus" APN settings, but VF NZ still accepts them and you are still online and being charged. For now your only option is to delete all APNs in Settings -> Wireless and Networks -> Mobile Networks -> Access Point Names.
    A firmware update that should be available by end of May will have an option to disable data all together without going into airplane mode or changing / deleting APN settings.
    Senior Member Nobby's Avatar
    and note that the APNdroid only stops connections establishing and doesn't kill current connections, what you should try is enabling APNDroid then switching into plane mode and them back again and that will stop connections, i have started using APNDroid at nights and have been blown away by how much battery it saves
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
  1. whats up everyone
    Last Post: 09-04-2010, 06:48 AM
