Wifi glitch is driving me nuts any solutions?
This is a discussion on Wifi glitch is driving me nuts any solutions? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Interesting...I use a Linksys WRT350N, and I have no issues whatsoever with my N1....
Results 11 to 13 of 13
Thread: Wifi glitch is driving me nuts any solutions?
    Metro Atlanta
    53 times
    Member Rocco D'Voe's Avatar
    Quote Originally Posted by davidalow44 View Post
    There's a problem with the N1 and some wireless-N routers, and I've seen the same symptoms myself. My N1 works fine with my Trendnet TEW-671BR, but can wedge a nearby Linksys wrt320n.
    My approach: avoid wireless-n routers until this is fixed.
    I called the csr this afternoon and sounds like they're aware of the problem and it is apparently something to do with certain N routers. Their suggestion was to do a factory reset, try out a different type of router that's not an N router, and last step is to send the phone in for warranty exchange.
    hopefully they'll have this problem addressed in the near future with an update.
    Senior Member rioja's Avatar
    I've had the problem in G routers too (D-Link & Belkin). The only router I've found to be reliable for me is the old Linksys WRT54G series.
