Deleting Wifi networks
This is a discussion on Deleting Wifi networks within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; How do I delete wifi networks from the list of SSIDs under Wifi settings? I just want them gone from the list. Even the ones ...
Thread: Deleting Wifi networks
    Junior Member gsferrari's Avatar
    I just want them gone from the list. Even the ones that are detected, I would like to remove them so I can start afresh.
    14 times
    Go into your wifi settings, tap the network you want and select Forget Network. That's it.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Thanks! That worked. I'm just not used to this Android business yet.
    Another issue and slightly more technical.
    My campus uses 802.1x authentication. This means I have to enter a username and password corresponding to my Active Directory settings. The Android interface does not allow me to do this even when I select 802.1x as the authentication. It only allows me to enter a password and clearly that doesn;t work.
    Is there any other Wifi application I can download and use?
  1. Hola!
    By G2 Forum User in forum Introductions & Site Assistance
    Last Post: 10-12-2010, 10:44 PM
android clear wifi history
android delete wifi network
android dellete wifi network
clear rememebered wifi from android
delete ssid android
delete wifi network history android
how to clear wifi history android
how to clear wifi history in android
how to delete unwanted wifi networks android
how to delete wifi history in android
how to delete wifi history on android
how to delete wifi histroy on android phone
how to delete wifi network on android tablet
how to remove wifi connection from android
how to remove wifi password from android phone
