Format SD Card, Re-inserted, Now running slow!
This is a discussion on Format SD Card, Re-inserted, Now running slow! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I Read up on here that the nexus one is having problems with the micro SD card so i removed it and then re-inserted it ...
Results 1 to 10 of 11
Thread: Format SD Card, Re-inserted, Now running slow!
    Junior Member Bigbenstrikes's Avatar
    I Read up on here that the nexus one is having problems with the micro SD card so i removed it and then re-inserted it and now its running really slow and says its preparing the SD card. I cant even unlock the phone as the touch screen combo thing is running that slow it locks before it finishes the pattern.
    Thanks
    Ben
    Quote Originally Posted by Bigbenstrikes View Post
    I Read up on here that the nexus one is having problems with the micro SD card...
    No, the Nexus One is not having problems w/ the SD card. It was just one person. You jumped to an incorrect conclusion.
    ...so i removed it and then re-inserted it and now its running really slow and says its preparing the SD card. I cant even unlock the phone as the touch screen combo thing is running that slow it locks before it finishes the pattern.
    You may have removed the SD card without turning the phone off.
    I suggest shutting down the phone completely, then removing the SD card and reinserting it. Then reboot.
    I did turn the phone off before i removed the battery and card... i have reinserted it and booted it up but the problems still occur?
    Any idea what it could be? I have removed the card for now andits running fine just not able to do a few things.
    Thanks
    Ben
    Possibly you did not reinsert the card correctly, or maybey the card was damaged when you removed it (since the phone seems to run "fine" without it.
    Try calling HTC and see if you can talk them into sending you another one.
    Deffinetly removed it properly...
    Ill try phoning them tommorow thanks
    Ben
    try and put the sd into a card reader on your pc see if you can read it,it might be faulty,just a suggestion
    Android Lurker maris's Avatar
    Also, be sure to unmount the SD card from your phone before removal, located under menu/settings/SD Card & Phone Storage.
    Junior Member dsyke's Avatar
    What is un mounting sd card?
    What does un mountint the sd card accomplish? I know how to do it, i just don't know why i should.
    Quote Originally Posted by Maris View Post
    The phone will unmount the card when you shut it down. You only to unmount if you want to remove the card without shutting down or if you want to access it via USB.
    You can also try booting the Nexus One in safe mode and then format the SD card and then reboot the phone and see if that does the trick.
android runs slow when i insert micro
android slow when sd card inserted
can formating sd card slow it down
computer is slow when microsd is inserted
formatting sd slow
preparing sd card slow
preparing sd card takes long time android
sd card running slow
sdcard suddenly got slower
