white envelope notification needs to always be manually cleared
This is a discussion on white envelope notification needs to always be manually cleared within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Whenever I get a SMS, I receive both the smiley chat bubble notification and the white square envelope new message notification. Is this normal? After ...
Thread: white envelope notification needs to always be manually cleared
    Junior Member waylo's Avatar
    Whenever I get a SMS, I receive both the smiley chat bubble notification and the white square envelope new message notification. Is this normal? After I read the message, the smiley chat bubble disappears, but the white square envelope remains. It won't go away unless I hit the clear button. If I press either, the message app shows up (i.e. both take me to the same place)
    I've searched the forums for multiple fixes, but haven't found one that worked.
    I used to have Handcent and ChompSMS installed. I messed around with notification settings for a while but none fixed it. They've now been uninstalled with no change in the notification.
    I went through and deleted all SMS messages in case I was somehow missing an unread message. Sending myself a new SMS still gave the same issue.
    I deleted K-9 mail reader in case this was somehow linked to the white square envelope notification. Apparently not.
    Fairly annoying. Anything else I'm missing? Don't know if it's worth doing a factory reset for this annoyance.
    Never mind, figured it out.
    double message notification - Page 3 - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Beautiful widgets 2 is the culprit!
    62 times
    Interesting! Thanks for posting issue and solution.
andriod enevelope notification
droid incredible notification envelope
how to remove the white envelope on the droid incredible
white envelope on a droid incredible
