Camera flicker
This is a discussion on Camera flicker within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Just got my nexus, and I'm truly blown away, what a phone. My bug is - camera flickers while taking pictures - everything in viewfinder ...
Thread: Camera flicker
    Junior Member Bronyr's Avatar
    Camera flicker
    My bug is - camera flickers while taking pictures - everything in viewfinder shakes, but sometimes it stabilizes itself. The quick fix is toggle between camera and camcoder - it's Ok. The fix works but it's annoying.
    Anyone?
    Junior Member nexus bound's Avatar
    I got mine last Friday and it is awesome.
    I just noticed last night that mine is doing this as well. I was looking at the screen, in landscape, with the camera open and noticed static like pink lines moving around at the bottom. When I got home I inspected further and saw the pink blob in the middle of the screen that I had read about. I kind of laughed about it because of all the "horror" stories of the pink blob ruining people's lives. I then noticed that the left side of the screen had a light hint of blue. The camera was trying to adjust itself, going in and out of a more normal image, then it would flicker. I do want to mention that the odd discoloration doesn't distort the image on the screen, it just hovers in and out. I can see perfectly fine what the camera is pointed at.
    I took some pictures and it seems that the bug doesn't affect the quality of the picture taken, then again I'm not a connoisseur of photography.
    I guess a sensor got rattled/wasn't properly installed? Doesn't even bother me one bit. In fact I didn't even think about calling HTC/Google until this afternoon, about the same time I finally exhaled from Friday.
    By the way, switching between camera and video showed no improvement or change. The video does it as well.
    After doing all I could (and they suggested) - this is a return item.
    I can't stand Google/HTC incompetence of not testing the product before shipping it out. If this happens again it will be my last dance with Nexus. Too bad because I love the phone otherwise, but can't put up with such poor quality of product put out to the public. No excuse for that.
    Hmm....
    Can anyone please take a look at this short video - is this hardware or software problem?... I think it's just drivers screwed up, but could be wrong:
    Video 4shared.com - online file sharing and storage - download Nexus flicker problem.mp4
    A factory reset would confirm if it's a software issue...
    as resetting can not cure a hardware fault.
    :nexusx: If you don't stand for something... You will fall for anything.:nexusx:
    not necessarily - if the driver is corrupt it could result in the same scenario.
    But it's likely the hardware.
    HTC didn't even test this particular phone - it's apparent right from the get go.
android camera flicker
android camera flickering
android phone camra flickrig problem
bosch camera flickering issues
camera flicker in nexus 6
camera flicker problem on android
camera screen flickering android phone
how to fix camera flickering android
htc camera flickering
htc flickering camera
htc one camera flicker
htc one camera flickering
htc one camere flicker
reset camera flickers android
why pink blob galaxy camera
