Phone lagging problem.
This is a discussion on Phone lagging problem. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Any more comment? I need more help....
Results 11 to 20 of 24
Thread: Phone lagging problem.
    Member Roger_1992's Avatar
    62 times
    Have you tried the suggestions, particularly the app killer?
    I have tried it helps thx.
    But i would like to conform with my total RAM.
    62 times
    Quote Originally Posted by Roger_1992 View Post
    Applications-Running Services..what do the bottom numbers total: Other + Available (what is their sum?)
    What do u mean by that? How can i check it?
    All i know that i shows me that my total ram is 217796kb.
    62 times
    Settings->Applications->Running Services..what do the bottom numbers total: Other + Available (what is their sum?)
    fixed......
    Avail: 11MB+104MB in 24
    Others:38MB in 3
    62 times
    Others:38MB in 3
    Factory Reset yet?
    I just did it. Now is shows..
    Avail: 93MB+64MN in 16
    Other: 28MB in 3
