Phone lagging problem.
This is a discussion on Phone lagging problem. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I'm sorry that i keep bugging about this but is my RAM normal?...
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Phone lagging problem.
  1. #21
    Member Roger_1992's Avatar
  2. #22
    Junior Member _kumar_nexusone's Avatar
    Apr 2011
    Cool
    i dont think tht RAM is good man... should be more... u did factory reset it correctly right?
  3. #23
    Unhappy
    Quote Originally Posted by _kumar View Post
    Yeah i did it n RAM is still low...
  4. #24
    Don't know but if I were you I would root and flash a custom ROM because from recovery when you facotry reset and clear cache and dalvik then you will probably be sending it even more reset that if you were just factory reseting it or maybe just make a second factory reset.
