Phone is very hot
This is a discussion on Phone is very hot within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I recently bought the case-mate tough case for my Nexus one and I noticed it started to get really hot after putting the case on. ...
Thread: Phone is very hot
    Member Euforeik's Avatar
    Unhappy Phone is very hot
    I recently bought the case-mate tough case for my Nexus one and I noticed it started to get really hot after putting the case on. It has reached up to 110F. i dont know if that is very hot but it feels like it. Has anyone else had problems with cases like this?
    Junior Member Yoonjin90's Avatar
    yea mine gets that hot if i have it plugged in and while im playing with it at the same time.
    So i tend to stay away from doing that.
    Member Roger_1992's Avatar
    Its same here for me. So i think its normal.
    Member Abrupt Demise's Avatar
    I've reached those temps as well. I just stop playing with it when it gets that warm.
    Android Lurker jameskevin's Avatar
    My phone doesn't get hot on 2.2 while charging or browsing the web
    Re: Phone is very hot
    Used the phone without a case for a day and it hasn't gotten hot at all.
    Junior Member blundell's Avatar
    Yeah gets hot if you max the processor and have it charging.
    The case probably insulates it even more. Bad design by the 3rd party
my android is very warm
