Quote Originally Posted by wingod View Post
I always wonder, if the more widgets you have, the more battery will be drained. But I cant live without widgets.
also, if turning off the gps, wont the weather not accurate?
Totally depends on what the widget is doing.
If you're talking about the weather widget, just set it to your ZIP code. That's will certainly be close enough, unless you're traveling.
