Dead or stuck pixel?
This is a discussion on Dead or stuck pixel? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I've seen many people having problems with dead/stuck pixels on their nexus one, but I'm not sure which I have. I've seen that you can ...
Results 1 to 10 of 10
Thread: Dead or stuck pixel?
    Junior Member SAKeller24's Avatar
    I've seen many people having problems with dead/stuck pixels on their nexus one, but I'm not sure which I have. I've seen that you can fix stuck ones, but dead ones mean sending it back to htc.
    The one pixel I'm having problems with is a constant blue color. I can see it on any background except a blue one. I figure this means its a stuck pixel as I would think a dead one wouldn't show any color ever.
    Can someone just clarify for me?
    There are apps top fix stuck pixels. Just search for pixel in the market
    I realize this. This doesn't answer my question of whether its stuck or dead though.
    62 times
    Quote Originally Posted by SAKeller24 View Post
    It's a flaw either way. Send away for a replacement.
    Does anyone know whether me buying it on ebay voids my warranty?
    For example, am I going to need a receipt or original order number?
    Is the warranty transferrable?
    Yes it is a stuck pixel, totally fixable. Try "JScreenFix". Might work for you,,
    Froyo 2.2 Stock
    RA-nexus-v1.7.0
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by ezeddiekun View Post
    Been running it pretty religiously all day. I do notice some fading, going from a dark, almost black, blue to a more sky blue now. I'm definitely encouraged and am going to keep running it quite a bit over the night and tomorrow to see what happens. Its at least less noticeable, which is good.
    this is what i was getting at
    Junior Member careick's Avatar
    I have in the top left corner of my N1 an orange half circle sort of tint that is always there. I got my N1 last Tuesday. It has been there since the moment I turned it on. I just installed that app, it is running right now, but does this sound like the same sort of issue??
    Member mush03's Avatar
    the screen shouldent have a tint to it
htc one stuck pixels
nexus s dead pixel
stuck pixel
stuck pixel nexus s
