Radio problems after 2.2 upgrade
This is a discussion on Radio problems after 2.2 upgrade within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Has anyone had radio (bluetooth, wifi, phone) issues after 2.2 upgrade. I find that my wifi after a while runs very slow or not at ...
Thread: Radio problems after 2.2 upgrade
    Junior Member abarron's Avatar
    Has anyone had radio (bluetooth, wifi, phone) issues after 2.2 upgrade. I find that my wifi after a while runs very slow or not at all, same for edge data. Toggling airplane mode corrects it for a while. Bluetooth doesn't completely resync when interrupted. The phone misses calls (not even in the call log). Never a problem before the upgrade. I have had the phone since January. Aside for the radio problem 2.2 the phone performs better.
    AT&T version or T-mobile version? rooted or stock?
    Nexus One and luvin it
    Rooted 5/6/2010
    Enomther 2.10.1 Froyo Release
    Quote Originally Posted by dimmakherbs View Post
    Thanks for responding. I was one of the early adopters and run the unlocked T-Mobile version. I went from stock 2.1 to froyo. This has the feel of a bit synchronization problem in that the sync recovery logic in the phone fails to recover clock (not time of day) from the incoming bit stream. when the radios are disabled (airplane mode) then re enabled it forces the logic to do a fresh resync.
    Member MrSlippers's Avatar
    I've noticed it too. It's strange because my receptions is a lot better then it was, but I've had it come to the point where I had to shut down the phone to get it to even attempt to pass traffic.
nexus 7 video stream constantly interrupted
nexus radio 5.6 bug fix
