Speakerphone problem
This is a discussion on Speakerphone problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; All my incoming calls are over the speakerphone by default so I have to try to turn the speakerphone off before continuing the call. The ...
Results 1 to 10 of 10
Thread: Speakerphone problem
    Junior Member peejayw's Avatar
    All my incoming calls are over the speakerphone by default so I have to try to turn the speakerphone off before continuing the call. The speakerphone button is often unresponsive and I am unable to to turn it off.
    Anyone else get this problem?
    62 times
    Quote Originally Posted by peejayw View Post
    How is it set to answer with speakerphone only? I wasn't aware of that setting...is this for a dock?
    No, not in a dock, the calls just come over the speakerfone and I have to turn it off but like I said, sometimes the speakerfone button is unresponsive.
    You're going to have to give a better explanation because, as Alphawave7 says, there is no way to default to speakerphone automatically (that we know of).
    Member lolobabes's Avatar
    My wifes N1 is having speaker phone is having a glitch after froyo update but mine is perfect though
    Heres the deal, I get a call, the callers voice comes over the external speaker, not the earpiece. That means each call I have to hit the speakerphone button to turn it off, sometimes I can, sometimes the button has no effect and the caller is still heard from the external speaker.
    Dont know how to say it any clearer than that, inward calls come over the external speaker by default and I cant always turn it off.
    Ok, we understand now. But that is not normal behavior or even a feature than any of the rest of us using 2.1 can enable. Are you using some application that provides this feature? Maybe that's what it is because this is not something that a "stock" phone can do.
    Member intenz's Avatar
    This happened to me today. I was like wtf?
    Quote Originally Posted by intenz View Post
    Are you guys using some application that might interfere with the normal operation of the phone?
    That is certainly not normal operation.
    I am using FroYo now but this has been happening for a long time now. In the past few days I have had a few calls come through normal but most still activate the speakerphone, what really bugs me is that usually the speakerphone button is unresponsive as well or at least takes multiple stabs at it to get the thing turned off !
android speakerphone default on
android speakerphone troubleshooting
problems with speakerphone for nexus
