Incoming calls wont ring or vibrate
This is a discussion on Incoming calls wont ring or vibrate within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; When I get an incoming call it will show up on the display but wont ring or vibrate. I'm running droidblock but I have it ...
Thread: Incoming calls wont ring or vibrate
    Junior Member Dawk20's Avatar
    When I get an incoming call it will show up on the display but wont ring or vibrate. I'm running droidblock but I have it set up to specific numbers not all numbers. I also have 2.2 running. Any ideas?
    Android Lurker maris's Avatar
    If you remove droidblock what happens? There may be a slight incompatibility with 2.2 right now.
    Thanks
    I tturned of the program and I have a ringtone now! I sent an email to the developer to notify them of the issue.
